ACS SE 4.2 haven't console access after Recovery CD-ROM
Jagdeep Gambhir Fri, 11/07/2008 - 08:14
  • Red, 2250 points or more
Was the recovery successful ? Try to restart it and see if that helps. Also make sure you use correct recovery cd. Like if you have 1113 then you need to use 1113 recovery and not 1112 recovery.
~JG
