NM-FE2W - V2 Not working on Cisco 3660
Nov 6th, 2008
I inserted a new NM-FE2W - V2 Card into a 3660 Cisco Router but the card is neither detected nor recognised when i dis "shop ip int brief" command. how can I activate this card and make it work on the 3660 Router with IOS image c3660-i-mz.122-5d? The card works on 3845 Router.
sly007 Fri, 11/07/2008 - 01:00
Thank you very much for your prompt response. I have suspected that the IOS is too old for the card. But please how best can I upgrade the IOS? I have attempted to upgrade it sometime ago, but at a stage, it requested for PCMCIA Card; and I dont have it, because I inherited the network, after the former administrator resigned.
Sushil Kumar Katre Sat, 11/08/2008 - 08:33
  • Gold, 750 points or more
If you are referring to "NM-1FE2W-V2" or "NM-2FE2W-V2" module then they are supported on 3600 series routers.
However the minimum IOS required for these second generation modules is - 12.2(12)M or 12.2(13)T.
Have a look at the datasheet -http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet09186a00801aa71c.html
You need an IOS upgrade.
