Spanning Tree: Link up
Nov 6th, 2008
I can find a lot about how spanningtree works when a port goes down. Different recovery time are possible on the chosen spanningtree.
But what happens when a trunk port comes active? Is only that one port going to learning mode or are all trunk ports on that switch going to learning mode?
And what happens if the new trunk port is closer to the root bridge?
Giuseppe Larosa Thu, 11/06/2008 - 11:33
  • Hall of Fame,
    Founding Member
Hello Paul,
a new link up is a topology change as well.
In classical STP 802.1D this triggers a recalculation in the whole network.
At the end of the calculation the new port will become the new Root Port for its lower path cost to the Root Bridge.
Using rapid spanning-tree convergence time is faster and the synchronization concept will help to confine the changes. The two parts will perform an handshake on the new link about proposed roles and states and will update the state of non-edge ports (ports not in portfast) accordingly to new scenario.
Be aware that if some STP protection mechanism is configured the new link can even be placed in a spanning-tree inconsistent state as a result of its attempt to become root port (spanning tree root guard or loop guard)
Hope to help
Giuseppe
