Cisco 871 / FE0-2 NATTED / FE3 BRIDGED - it's possible ?
Nov 6th, 2008
at the moment I have configured the 871 with a simple pppoe negotiation on the WAN port (FE4) and on the FE0-3 I have the private LAN (NATTED).
Now, I want to configure the FE3 in bridge mode with the WAN port, so that I can connect my servers using the other public ip assigned by the ISP.
Its possible to coexist some ports natted with a bridged port ?
this is my basic configuration:
no service pad
service password-encryption
hostname <REMOVED>
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
enable secret 5 <REMOVED>
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name <REMOVED>
ip name-server 212.x.199.2
ip name-server 212.x.192.190
username <REMOVED> privilege 15 secret 5 <REMOVED>
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname <REMOVED>
ppp chap password 7 <REMOVED>
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
ip nat inside source list 101 interface Dialer0 overload
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
End
I think that I need to create a VLAN (ex. vlan10), assign it on the port FE3, enable irb and create a brdige group beetwen wan and FE3.....
ideanet77 Mon, 11/10/2008 - 08:33
have tried to configure bridge mode on the Fastethernet3, but doesn't work. anyone can help me ?
this is my configuration: the LAN (Fe0-2) works fine, I have problem only on the dmz (fe3).
no service pad
hostname
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
dot11 syslog
ip cef
ip dhcp excluded-address 10.10.1.1 10.10.1.59
ip dhcp excluded-address 10.10.1.100 10.10.1.254
ip dhcp pool VLAN1
import all
network 10.10.1.0 255.255.255.0
default-router 10.10.1.1
domain-name
dns-server 212.90.199.2 212.90.192.190
lease 0 2
no ip domain lookup
ip domain name
ip name-server 212.90.199.2
ip name-server 212.90.192.190
username privilege 15 secret 5
archive
log config
hidekeys
ip ssh time-out 60
bridge irb
switchport access vlan 10
no ip address
duplex auto
speed auto
interface Vlan1
ip address 10.10.1.1 255.255.255.0
ip nat inside
interface Vlan10
no ip address
bridge-group 10
bridge-group 10 spanning-disabled
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname
ppp chap password 7
interface BVI10
no ip address
ip access-group 102 in
ip http server
access-list 101 permit ip 10.10.1.0 0.0.0.255 any
access-list 102 permit ip any any
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 10 route ip
banner login ^CCAuthorized access only!
line con 0
login local
no modem enable
line aux 0
login local
line vty 0 4
privilege level 15
login local
End
thank you for help
Luca
