Interdigit timeout
Nov 6th, 2008
I have CCM 6.1.2 and when I dial internally it take about 3 seconds after I dial the digits.
I changed the T.302 Service Parameter to minimum to 3000, but still the issue persists.
Thanks..
Jaime Valencia Thu, 11/06/2008 - 12:04
look at the route plan report for ovelapping
there must be something there causing this, look for exact matches, then for patterns with wildcards.
you can use DNA for this purpose
java
if this helps, please rate
