PING time from Wireless Clients
We have over 150 AP's installed.
1. I am noticing the below type of PING times from various clients attached to various AP's at different locations. Very few locations r reporting <2ms.
Reply from 172.26.5.111: bytes=32 time=106ms TTL=127
Reply from 172.26.5.111: bytes=32 time=2ms TTL=127
Reply from 172.26.5.111: bytes=32 time=51ms TTL=127
Reply from 172.26.5.111: bytes=32 time=74ms TTL=127
Reply from 172.26.5.111: bytes=32 time=101ms TTL=127
Reply from 172.26.5.111: bytes=32 time=113ms TTL=127
Reply from 172.26.5.111: bytes=32 time=754ms TTL=127
Reply from 172.26.5.111: bytes=32 time=162ms TTL=127
Reply from 172.26.5.111: bytes=32 time=92ms TTL=127
Reply from 172.26.5.111: bytes=32 time=14ms TTL=127
Reply from 172.26.5.111: bytes=32 time=37ms TTL=127
Reply from 172.26.5.111: bytes=32 time=61ms TTL=127
Reply from 172.26.5.111: bytes=32 time=70ms TTL=127
Reply from 172.26.5.111: bytes=32 time=94ms TTL=127
Reply from 172.26.5.111: bytes=32 time=19ms TTL=127
Reply from 172.26.5.111: bytes=32 time=40ms TTL=127
Reply from 172.26.5.111: bytes=32 time=168ms TTL=127
Reply from 172.26.5.111: bytes=32 time=87ms TTL=127
Reply from 172.26.5.111: bytes=32 time=9ms TTL=127
Reply from 172.26.5.111: bytes=32 time=33ms TTL=127
Reply from 172.26.5.111: bytes=32 time=267ms TTL=127
Reply from 172.26.5.111: bytes=32 time=81ms TTL=127
The PING times to LAN users is fine. Looking for directions to troubleshoot.
Thanks!
jeff.kish Thu, 11/06/2008 - 13:02
  • Silver, 250 points or more
Believe it or not, this can be normal for a wireless environment. But a few questions - what are you pinging? Are you pinging the access point, or some other device on the network? Are you running lightweight or autonomous?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
