How to: Erase recorded voice from one Subscriber?
Nov 6th, 2008
We have the Unity 4.2 and i would like to know how i can change the recorded voice to default system ? Likes "you called to number number number (xxxx) its not available, leave your message now...." not likes "you called to SR. JOHN ........"
thanks,
ranpierce Thu, 11/06/2008 - 13:37
  • Silver, 250 points or more
on the profile page of the subsriber check the Set subscriber for self-enrollment....
Then log in and go through enrollment, do not record a name this time.
you can use bulk edit to set self enrollment.
I know of another way in sql too.
Randy
odinhuodin Fri, 11/07/2008 - 04:55
Hello I suspected that was simple, in a unity of tests I only entered the Subscriber> Recorded Voice> Option Menu> and click the New and Save. After that, the message returned to default ... "This is the number of voice mail ... "
Thanx for Reply ranpierce.
