Dynamic Topology Map??
Nov 6th, 2008
Hi guys,
I'm new to LMS but was wondering if it has a dynamic view of the topology? So if I were to power off a device or disconnect a link, will this be reflected dynamically in the topology map? I've gotten email alerting to work fine though. Is this at all possible?
Thanks in advance,
Joe Clarke Thu, 11/06/2008 - 15:05
Campus Manager is not a fault management application. It is designed to provide documentation of your layer 2 network. However, as of LMS 3.1 and Campus Manager 5.1, there is integration between Campus and DFM. If DFM detects an event corresponding to a given device, the device icon will change on the Campus Map to reflect the severity of the most severe event DFM has detected. This may mean your icons have a stop sign, yield sign, or informational sign on top of them.
bevan.barry Fri, 11/07/2008 - 03:36
Thanks for the info jclarke. I've got LMS 3.1 with Campus Manager 5.1 setup in a lab environment. I've powered switch off and disconnected links but the topology stayed as is even after I refresh it a few times although the notification email were sent. Any ideas?
Joe Clarke Fri, 11/07/2008 - 09:30
Go to Campus Manager > Admin > Topology > DFM Poller Settings, and make sure you have Poll DFM Server for alerts enabled. After doing that, your topology map will update with DFM events.
bevan.barry Fri, 11/07/2008 - 13:55
Thanks again for the info but I just gave it a try and it didn't work with that option enabled. I also noticed that the minimum value was 6 mins. So doesn't that mean I'd have to wait 6 mins for the topology to update?
Thanks in advance,
Joe Clarke Fri, 11/07/2008 - 14:30
Yes, you will have to wait at least six minutes for Campus to pull the latest DFM data. You may also have to relaunch Topology Services after enabling the feature.
