Deleting unknown users from grantunityaccess
dknov
Level 3
Level 3
A quick one. I have some entries marked <Unknown> when running
"-l" option of grantunityaccess.
Does anyone know how can these be deleted? Unity seems to save them in SQL cause they get replicated between primary and failover, but I can't find the table...
David
Jaime Valencia
have you tried using the credentials map???
available at unity tools online, you can easily select a user and strip off credentials
otherwise look for subscribers table in SQL
java
if this helps, please rate
java
Jaime Valencia
java
java
