ASA 8.x in transparent mode with DMZ
Nov 6th, 2008
I just want to confirm that a DMZ cannot be used in transparent mode. I have a need to be in transparent mode, but also need a DMZ. Are there any workarounds?
My other choice is to NAT the servers in the DMZ to an address space that exists on the outside.
Fernando_Meza Thu, 11/06/2008 - 15:54
  • Gold, 750 points or more
You could have 2 contexts. Allocate 2 separate interfaces to context #1 (running on transparent mode) and the rest to context #2 (running on route mode). Of course there is some design involved but this is probably your way around it if applicable on your topology.
I hope it helps .. please rate helpful posts.
dhananjoy chowdhury Thu, 11/06/2008 - 23:03
  • Silver, 250 points or more
For the ASA firewall in multiple context mode, you can use only one firewall mode for all contexts, i.e, either transparent or routed mode.
Only starting from ASA/PIX 8.0(2), NAT/PAT is supported in the transparent firewall.
In FWSM, its possible to have mix of both transparent and routed mode firewall contexts on the same box.
