VSS: How to change Boot variable after.....
Nov 6th, 2008
you have already messed up the boot varibles configuration on your VSS-6509 and now the switch would not boot. I can get to the rommon> and set confreg to 0x2142 then reset the switch but it DID NOT ignores the the saved config.
