UCCX 5.02 Real Time Reporting
Nov 6th, 2008
I have installed 2 of this version so far and the Real Time Reporting page through appadmin is always blank! Is this a bug and ifso whats the fix? Cheers!
Anthony Holloway Thu, 11/06/2008 - 19:45
I'm not sure what you installed, but the RTRT is a Java applet.
You need a specific version of the JVM installed in order to see the stats.
Check your Java version compatibility here:
You could always launch RTRT from a Remote Desktop session to the server.
Chad Stachowicz Fri, 11/07/2008 - 09:31
Its from the server that you cannot do it! both in 5.02 build 64 and 5.02 SR1. Any idea what versions of java I need on the server, and am I allowed to change it on the server.
Chad Stachowicz Sun, 11/09/2008 - 10:55
Awesome thanks dude. I do however think its ridiculous they aren't including the version of java needed to run this actually the version on the server.
Anthony Holloway Sun, 11/09/2008 - 19:29
The correct version is installed by default. You have to watch out for the Java system tray icon. It will keep trying to get you to update it. Perhaps you, or someone else with access to the server, updated it.
We have had problems where the java was updated on a supervisors PC (not the server) and that supervisor couldn't pull the Real Time reporting page from just their PC. It worked fine from other PC's and from the server itself, but had stopped working on the specific user's PC due to that user having updated their Java for another application. Same blank page, with no error. Took us a while to figure out what the actual problem was and what version of Java was required.
