How to disable core dump on failing Sup720
Nov 6th, 2008
I have setup redundancy on my cat 6509 with dual sup720s
in the cat 6500 configuration guide
it states:-
Supervisor engine switchover takes place after the failed supervisor engine completes a core dump. A core dump can take up to 15 minutes. To get faster switchover time, disable core dump on the supervisor engines
how is this done? I cannot find the command to disable a core dump
Overall Rating: 5 (1 ratings)
Amit Singh Fri, 11/07/2008 - 01:13
just type command "no exception dump" or
"no exception flash".
Check for any " execption" command in your running config and just disable it using the "no " form.
-amit singh
Richard Bradfield Fri, 11/07/2008 - 17:04
thanks for your prompt reply, I have checked it out as per your response
