asa5510 logs
Nov 6th, 2008
Hi all. I have enabled syslogging on my cisco asa5510. However it seems i can't get any logging about outgoing connections. For example i connect to a mail server for sending/downoloading of email. But when i check the log i only see teardown of connection to the mail server and no logs about build outbound connection. I need to verify via logs about building of outbound connection because there are some sites which my users state they could not connect. Even though i do not block any outgoing traffic, i would like to verify via logs. Pls advise, thks in advance.
Collin Clark Fri, 11/07/2008 - 10:47
  • Purple, 4500 points or more
Try changing your logging level that's sent to syslog. Start at debug and work your way down.
logging trap debugging
Hope that helps
