CUCM 6.0.1 - Media Routing through the server
Nov 6th, 2008
I have CUCM 6.0.1.3000-7 and registered two third party SIP device to the Server.
While I am making the call between these two devices, the media (RTP) is flowing end to end, not through CUCM.
I want to route all the media(RTP) through CUCM. How is it possible?
Overall Rating: 4 (2 ratings)
Keith Fulcher Fri, 11/07/2008 - 01:34
Media is always end to end.......even with the phones. Only the signaling is routed to the CUCM. I doubt there is a way to do this.
Jaime Valencia Fri, 11/07/2008 - 10:34
CUCM is only a call agent, signaling is stimulus-response. RTP is always between endpoints, that's the whole point of call preservation. if CCM fails, calls are preserved because RTP is between endpoints.
java
if this helps, please rate
nissarbm_ece Sat, 11/08/2008 - 02:01
Thanks for your response.
With the SCCP supported devices, does the media is routed through the CUCM ?
Jaime Valencia Sat, 11/08/2008 - 08:17
no, CUCM does not make media flow-thru
in any protocol
media is between devices. only reason a device sends media to CCM is to use the SW CFB.
if you need that start looking at CUBE
java
nissarbm_ece Sun, 11/09/2008 - 20:36
What is thins SW CFB and CUBE?
You have any reference link to these topics?
Jaime Valencia Mon, 11/10/2008 - 07:08
Software Conference Bridge
Cisco Unified Border Element
Documentation can be easily found in CCO
java
