LMS reports ANI server down
Answered Question
Nov 6th, 2008
I'm using Cisco Campus manager 4.0.6. The main issue is that Device discovery fails and I get the error that "ANI Server is down"; when i restart the process, it goes into the state, "The administrator has shut down this server".
Correct Answer by Joe Clarke about 8 years 2 months ago
Please start a new thread for your Discovery issue.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 11/06/2008 - 22:59
It appears that the RmeGatekeeper daemon is not running properly. Please post the output of the pdshow command.
Joe Clarke Fri, 11/07/2008 - 09:51
This appears to have been truncated. There are at least two daemons for which I need to see status.
Joe Clarke Wed, 11/26/2008 - 08:37
Please post a screenshot of your Services control panel showing all of the CiscoWorks and CWCS services.
Joe Clarke Thu, 11/27/2008 - 09:24
None of these were what I wanted. I want screenshots of the Windows Service control panel (the one under Administrative Tools) showing the startup parameters of the CiscoWorks and CWCS services.
Joe Clarke Mon, 12/01/2008 - 06:54
This is fine. Please post the RmeGatekeeper.log. Additionally, shutdown Daemon Manager, and post the output of:
netstat -a -n -o -b
Joe Clarke Wed, 12/03/2008 - 10:32
FrameworkService (PID 1448) is occupying the required port tcp/9091. Shut this service down, then restart Daemon Manager, and you should be set.
anthony_m Fri, 12/05/2008 - 01:48
I managed to do away with the errors and started device discovery. After running device discovery, I looked at the discovery report and it shows that the seed device is unreachable. Yet I can ping the seed device from the LMS server.
What could the issue be?
Correct Answer
Joe Clarke Fri, 12/05/2008 - 11:27
