Joe Clarke Thu, 11/06/2008 - 23:02
It looks like your Perl executable may be bad. What is the byte size of NMSROOT\bin\perl.exe? What is the output of NMSROOT\bin\perl -V?
riko.arizona Sun, 11/23/2008 - 19:23
The size of NMSROOT\bin\perl.exe is 21 KB. Please see attached For the output of NMSROOT\bin\perl -V
Joe Clarke Sun, 11/23/2008 - 19:35
Try unsetting PERL5LIB before running the logrot.pl command:
SET PERL5LIB=
F:\PROGRA~1\CSCOpx\bin\perl.exe F:\PROGRA~1\CSCOpx\bin\logrot.pl -c
Joe Clarke Sun, 11/23/2008 - 19:37
Also, check the size of logrot.pl. It should be 38,777 bytes in LMS 3.0.1.
Joe Clarke Sun, 11/23/2008 - 20:07
That's why. Your logrot.pl has been corrupted. You need to either restore this file from a file system backup, or reinstall Common Services.
riko.arizona Thu, 12/04/2008 - 23:13
How to reinstall Common Service? I try to uninstall but it can't. I try to download CommonService, but I can't find.
Joe Clarke Tue, 12/16/2008 - 22:34
This is the LMS 3.0.1 update. This is not sufficient. You need to reinstall CS 3.0. That will not be easy if you have already applied LMS 3.0.1. You should work with TAC to reinstall Common Services, or reinstall all of LMS from scratch, then restore a current data backup.
