WiSM Etherchannel not coming up on 6513
Nov 7th, 2008
I have a wism installed on my 6513 but the moment i assign ports g12/1-4 to Po1 and Ports G12/5-8 to Po2 the are no coming up the configuration of the Ports including Po1 and Po2 are as follows:
interface range GigabitEthernet12/1-4
switchport
switchport trunk native vlan 137
switchport mode trunk
switchport nonegotiate
no ip address
no snmp trap link-status
mls qos trust cos
no cdp enable
interface range GigabitEthernet12/5-8
switchport
no ip address
mls qos trust cos
no cdp enable
wism module 12 controller 1 native-vlan 137
wism module 12 controller 2 native-vlan 137
The moment i assign the ports to their respective channel-group they all goes down, I tried to unshut them manually but no luck. IOS version is (s72033_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF7.
renato.berana Fri, 11/07/2008 - 05:26
Port channels are configured properly, but for unknown reason the etherchannel are not coming up
jakew Fri, 11/07/2008 - 07:08
Configure the channel-group and enable that first.
Scott Fella Fri, 11/07/2008 - 07:14
You have the service ports showing UP? Also, run a show etherchannel load-balance and make sure it is setup for src-dst-ip. if not run this command port-channel load-balance src-dst-ip
renato.berana Fri, 11/07/2008 - 11:27
Yup all service ports are up, i can even access the management GUI but without the etherchannel, once i add the ports to their respective channel-group they are all switching to disabled mode.
krishanmistry Sun, 11/09/2008 - 02:18
Make sure your not using port channels 1-13, use anything above 13 and they should come up, this is a bit of a gotcha with the WiSM.
E.g Port channel
interface Port-channel20
description ***PORT_CHANNEL_WiSM_1_WLC1***
switchport
switchport trunk native vlan #
switchport trunk allowed vlan #,#
no ip address
interface Port-channel21
description ***PORT_CHANNEL_WiSM_1_WLC2***
switchport
no ip address
Interface Example
interface GigabitEthernet2/8
description ***8Gbps_GEC to Switch 2***
switchport
no ip address
channel-group 21 mode on
Please rate this post
tkhan Tue, 11/11/2008 - 11:13
If you want to get away from the port channel configuring of the WiSM, try these commands:
wism module controller 1 allowed-vlan
wism module controller 2 allowed-vlan
wism module controller 1 native-vlan
wism module controller 2 native-vlan
These statements are available on SXF5 and later, I think. I'm running 12.2(18)SXF9. (SUP720)
Here is a statement from the documentation:
Note: Software Release 12.2(18)SXF5 introduced new WiSM commands to use with auto-LAG ports (in the high 200 range). These commands can be used instead of steps 5 and 6 . Repeat the two commands for controller 1 and controller 2 in the WiSM module.
wism module controller 1 native-vlan 40
wism module controller 1 allowed-vlan native vlan id(40), vlan id1, vlan2
renato.berana Thu, 11/13/2008 - 04:29
Hi Buddy, i configured port-channel 15 and 16 and the etherchannel are working fine now. the problem now is I am not able to connect to the WiSM management.
tkhan Thu, 11/13/2008 - 06:00
Have you setup your service port vlan? You can use it to check your management interface configurations or use the console port.
Example:
ip dhcp pool wism-service-port
network 192.168.0.0 255.255.255.248
default-router 192.168.0.1
wism service-vlan 192
interface Vlan192
ip address 192.168.0.1 255.255.255.248
end
krishanmistry Thu, 11/13/2008 - 12:21
Make sure the native Vlan for trunk on all 8 interfaces is the management VLAN tag, and make sure the management interface on the WiSM are untagged (0).
Hope this helps,
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
