Amit Singh Fri, 11/07/2008 - 02:13
  • Cisco Employee,
You can use 4-port HWIC card on 3845. You will have 16 serial ports on the router. Is it a serial interface that you require on the router or an E1 interface?
chrislau388 Tue, 11/11/2008 - 07:34
Some of my WAN links are 1024k and some are 2048k.
HWIC-4T card is the module that I need
Sushil Kumar Katre Sat, 11/08/2008 - 08:24
  • Gold, 750 points or more
If you are referring to HWIC-4T1/E1 module, yes you can have 4 such modules in 3845.
But before deciding on this module please have a look at the limitations/restrictions of this module, for instance it does not supports voice -
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_11xw/fmt1e1ic.html#wp1054676
Datasheet - http://www.cisco.com/en/US/prod/collateral/modules/ps5949/product_data_sheet0900aecd80710c77.html
-> Sushil
