HSRP and L3 issues on Cisco 7609
Nov 7th, 2008
Hi. Firstly thanks for your time. Secondly, I have 2 major issues in regard of HSRP at L3 level as following:
Suppose that we have an SVI VLAN 120 with 2 different subnets (prim. & sec ip). We run HSRP on mentioned int Vlan by 2 different groups. So, the problem is each of our router is just able to ping it's phys. ip addr. along with the vir. ip addr. of HSRP, but it can not ping the phys. ip addr. of it's corresponding redundant router. Moreover, when I tried to ping the loopback address of adjacent router, it's not possible. I've checked all issues in regard of L2/L3 but found nothing! (We have IOS 12.2 (33) SRB2 & RSP720 on our routers). So, have anyone had the same issues as for now?! Can we say that it has a relation to IOS or Hardware matters?! Please kindly advise. Thanks & Regards,
Amit Singh Fri, 11/07/2008 - 03:09
  • Cisco Employee,
Could you please paste the config from the primary and standby routers.
medi.mazinani Fri, 11/07/2008 - 03:52
Hi Asingh, I will paste the MSTP/HSRP/SVI and Ping test results of mentioned issues. Is it sufficient? Thanks for the support.
medi.mazinani Fri, 11/07/2008 - 03:58
Router1 (RTHG1):
MSTP:
{spanning-tree mode mst
spanning-tree mst configuration
name RTHG
revision 1
instance 1 vlan 10-29, 50-69, 100-119, 140-179, 220-239
instance 2 vlan 30-49, 70-99, 120-139, 180-219, 240-361
spanning-tree mst 1 priority 0
spanning-tree mst 2 priority 4096
interface Loopback0
ip address 10.12.200.1 255.255.255.255
interface Port-channel1
description GE47&GE48 RTHG1 to GE47&GE48 RTHG2
switchport
switchport mode trunk
interface GigabitEthernet1/47
description trunk (EtherChannel) to RTHG2 GE47
switchport
speed 1000
duplex full
spanning-tree link-type point-to-point
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/48
description trunk (EtherChannel) to RTHG2 GE48
switchport
speed 1000
duplex full
no cdp enable
interface Vlan120
description MAGD_OMU
ip address 10.12.101.2 255.255.255.224 secondary
ip address 10.12.100.2 255.255.255.224
no ip redirects
standby 3 ip 10.12.101.1
standby 3 timers 1 3
standby 3 priority 80
standby 3 preempt delay minimum 180
standby 120 ip 10.12.100.1
standby 120 timers 1 3
standby 120 priority 80
standby 120 preempt delay minimum 180
All mentioned interfaces ar UP.
MSTP is OK; HSRP: sh stand br,
RTHG1#sho span mst conf
Name [RTHG]
Revision 1 Instances configured 3
Instance Vlans mapped
0 1-9,362-4094
1 10-29,50-69,100-119,140-179,220-239
2 30-49,70-99,120-139,180-219,240-361
RTHG1#sho stand br
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Vl120 3 80 P Standby 10.12.100.3 local 10.12.101.1
Vl120 120 80 P Standby 10.12.100.3 local 10.12.100.1
Will send Router2's configs in another message. Tnx,
medi.mazinani Fri, 11/07/2008 - 04:03
Router2 (RTHG2):
MSTP:
name RTHG
revision 1
spanning-tree mst 1 priority 4096
spanning-tree mst 2 priority 0
interface Loopback0
ip address 10.12.200.2 255.255.255.255
description GE47&GE48 RTHG2 to GE47&GE48 RTHG1
switchport
description trunk (EtherChannel) to RTHG1 GE47
switchport
speed 1000
duplex full
channel-group 1 mode passive
description trunk (EtherChannel) to RTHG1 GE48
switchport
speed 1000
duplex full
interface Vlan120
ip address 10.12.101.3 255.255.255.224 secondary
ip address 10.12.100.3 255.255.255.224
no ip redirects
standby 3 priority 110
standby 120 priority 110
RTHG2#sho stand br
Vl120 3 110 P Active local 10.12.100.2 10.12.101.1
Vl120 120 110 P Active local 10.12.100.2 10.12.100.1
Also pls. take into ur consideration that the Active Virt. router for both subnet is the same (???). Moreover, I don' know y I have no information for my port channel member links (1/47,48) in MSTP results? (Continued ...)
medi.mazinani Fri, 11/07/2008 - 04:18
MSTP: sho span mst
RTHG2#sho span mst
##### MST0 vlans mapped: 1-9,362-4094
Bridge address --.6240 priority 32768 (32768 sysid 0)
Root address --.5780 priority 32768 (32768 sysid 0)
port Po1 path cost 0
Regional Root address --.5780 priority 32768 (32768 sysid 0)
internal cost 10000 rem hops 19
Operational hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured hello time 2 , forward delay 15, max age 20, max hops 20
Interface Role Sts Cost Prio.Nbr Type
Gi1/1 Desg FWD 200000 128.1 P2p
Gi1/2 Desg FWD 200000 128.2 P2p
Gi1/27 Desg FWD 20000 128.27 Edge P2p
Gi1/43 Desg FWD 200000 128.43 Edge P2p
Po1 Root FWD 10000 128.3329 P2p
##### MST1 vlans mapped: 10-29,50-69,100-119,140-179,220-239
Bridge address --.6240 priority 4097 (4096 sysid 1)
Root address --.5780 priority 1 (0 sysid 1)
port Po1 cost 10000 rem hops 19
Gi1/3 Desg FWD 200000 128.3 P2p
Gi1/4 Desg FWD 200000 128.4 P2p
Gi1/5 Desg FWD 200000 128.5 P2p
Gi1/6 Desg FWD 200000 128.6 P2p
Gi1/7 Desg FWD 200000 128.7 P2p
Gi1/8 Desg FWD 200000 128.8 P2p
Gi1/9 Desg FWD 200000 128.9 P2p
Gi1/10 Desg FWD 200000 128.10 P2p
Gi1/19 Desg FWD 200000 128.19 P2p
Gi1/20 Desg FWD 200000 128.20 P2p
Gi1/21 Desg FWD 200000 128.21 P2p
Gi1/22 Desg FWD 200000 128.22 P2p
Gi1/23 Desg FWD 200000 128.23 P2p
Gi1/24 Desg FWD 200000 128.24 P2p
##### MST2 vlans mapped: 30-49,70-99,120-139,180-219,240-361
Bridge address --.6240 priority 2 (0 sysid 2)
Root this switch for MST2
Po1 Desg FWD 10000 128.3329 P2p
HSRP ambiguities are here:
RTHG1#ping 10.12.100.1
Sending 5, 100-byte ICMP Echos to 10.12.100.1, timeout is 2 seconds:
Success rate is 0 percent (0/2)
RTHG1#ping 10.12.100.2
Sending 5, 100-byte ICMP Echos to 10.12.100.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
RTHG1#ping 10.12.100.3
Sending 5, 100-byte ICMP Echos to 10.12.100.3, timeout is 2 seconds:
RTHG1#ping 10.12.101.1
Sending 5, 100-byte ICMP Echos to 10.12.101.1, timeout is 2 seconds:
RTHG1#ping 10.12.101.2
Sending 5, 100-byte ICMP Echos to 10.12.101.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
RTHG1#ping 10.12.101.3
Sending 5, 100-byte ICMP Echos to 10.12.101.3, timeout is 2 seconds:
RTHG1#sho stand vlan 120
Vlan120 - Group 3
State is Standby
4 state changes, last state change 00:01:46
Virtual IP address is 10.12.101.1
Active virtual MAC address is --.ac03
Local virtual MAC address is --.ac03 (v1 default)
Hello time 1 sec, hold time 3 sec
Next hello sent in 0.480 secs
Preemption enabled, delay min 180 secs
Active router is 10.12.100.3, priority 110 (expires in 2.448 sec)
Standby router is local
Priority 80 (configured 80)
Group name is "hsrp-Vl120-3" (default)
Vlan120 - Group 120
State is Standby
Virtual IP address is 10.12.100.1
Active virtual MAC address is --.ac78
Local virtual MAC address is --.ac78 (v1 default)
Group name is "hsrp-Vl120-120" (default)
Success rate is 0 percent (0/5)
medi.mazinani Fri, 11/07/2008 - 04:19
RTHG2#sho stand vlan 120
Vlan120 - Group 3
State is Active
2 state changes, last state change 00:04:36
Next hello sent in 0.384 secs
Active router is local
Standby router is 10.12.100.2, priority 80 (expires in 2.464 sec)
Priority 110 (configured 110)
Vlan120 - Group 120
State is Active
RTHG2#ping 10.12.100.1
RTHG2#ping 10.12.101.1
RTHG2#ping 10.12.100.2
RTHG2#ping 10.12.101.2
LP not pinged!:
{RTHG1# ping 10.12.200.2
Sending 5, 100-byte ICMP Echos to 10.12.200.2, timeout is 2 seconds:
RTHG1#
{RTHG2#ping 10.12.200.1
Sending 5, 100-byte ICMP Echos to 10.12.200.1, timeout is 2 seconds:
LP investigation:
RTHG1#ping 10.12.200.2
RTHG1#ping 10.12.200.2 sour loo 0
Packet sent with a source address of 10.12.200.1
RTHG1#sho ip rou | inc 10.12.200
C 10.12.200.1/32 is directly connected, Loopback0
O 10.12.200.2/32 [110/2] via 10.12.120.19, 00:09:17, Vlan241
RTHG2#ping 10.12.200.1 sour loo 0
Packet sent with a source address of 10.12.200.2
RTHG2#sho ip route | inc 10.12.200
O 10.12.200.1/32 [110/2] via 10.12.120.18, 00:10:36, Vlan241
C 10.12.200.2/32 is directly connected, Loopback0
RTHG2#tra 10.12.200.1
Tracing the route to 10.12.200.1
1 10.12.108.2 0 msec
10.12.108.34 0 msec
10.12.120.18 0 msec
RTHG2#ping 10.12.200.1 sour vlan 241
Packet sent with a source address of 10.12.120.19
RTHG2#ping 10.12.200.1 sour vlan 360
Packet sent with a source address of 10.12.108.35
RTHG2#
That's all. Please keep me posted if you have any upd. in this regard. Really appreciate it. BR,
medi.mazinani Fri, 11/07/2008 - 05:32
Hi buddy. Did u have any time for taking a look on enclosed logs? Did u find anything? I will proceed with changing IOS to 12.2 (18) SXF9, maybe it's working.
medi.mazinani Sat, 11/08/2008 - 00:47
Hey. No one has no idea in this regard? If someone can give a pro support, it would be highly appreciated. Believe me or not, no one can not help me as for now in this regard! BR,
Giuseppe Larosa Sat, 11/08/2008 - 11:48
  • Hall of Fame,
    Founding Member
Hello Medi,
first of all I would suggest you next time to attach the config and shows in an attachement file instead of using multiple posts.
It makes easier to understand the thread is still at the beginning...
I noticed one configuration issue:
when you want to configure an HSRP group that has to be associated to a secondary ip address you need to add the secondary keyword:
interface Vlan120
no ip redirects
last line needs to be:
standby 3 ip 10.12.101.1 secondary
B)
any command should be on the port-channel interface not on the member links
I would put
under port-channel
but I think that this command is not needed.
c)
fix the missing secondary option and retry.
Hope to help
Giuseppe
medi.mazinani Sat, 11/08/2008 - 23:55
Hi Giuseppe,
Firstly thanks for your advise in regard of attaching configs. Will proceed so afterwards.
Secondly, indeed I had tried ur suggested solution in regard of HSRP sec, but it did not work at all!
