mikram Fri, 11/07/2008 - 03:14
  • Bronze, 100 points or more
Please explain what do you mean redundant CM solution. If you have one cluster, you dont need to replicate IP Phones licenses.
Cheers
Ikram
abartolomeu Fri, 11/07/2008 - 03:50
One cluster.
What about LIC-CM6.1-7816= (License Unified CM 6.1 7816 Appliance, 500 seats
)? I should need two of these for the two HP 7816 servers, right?
Jaime Valencia Fri, 11/07/2008 - 07:22
  • Cisco Employee,
  • Hall of Fame,
    2011
still not clear. if you have only 1 cluster the licensing server replicates the information to all servers in cluster. you only need the process node license per server if you want to start CCM service
if you mean you want to have another cluster with exact same config in case working cluster crashes, then yes, licensing is completely separate
java
if this helps, please rate
Chris Deren Fri, 11/07/2008 - 07:29
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You need node license for each server in the cluster, so you would need LIC-CM6.1-7816= for every server (or whatever the server model is). Unless you go with CUWL licensing, which gives you unlimited (up to supported) number of node licenses. You do not need to duplicate the DLU licenses.
HTH,
Chris
