ATA 186: T.38 support?
Nov 7th, 2008
does the ATA 186 supports T.38 for fax conections? If not, which model does support T.38?
Thank you!
Eric Krieger Fri, 11/07/2008 - 05:59
Hi Johan,
The ATA-186 does only support Fax-Pass-through (upto 14.4k!).
An ISR with an analogue Voice/Fax modules would support T.38 as well.
You can also wait for the upcoming VG202/VG204 gateways which are new 2 or 4 ports analogue gateways, more or less "replacements" for the ATA-186.
Eric Krieger Fri, 11/07/2008 - 06:30
ISR = "Integrated Services Routers"
Like the 28xx, 38xx, etc. kind of routers, with (expansion) slots for (NM, VIC, VWIC, etc) modules(like a FXS module for analogue lines, for example).
Eric Krieger Mon, 11/10/2008 - 15:00
Cisco does only have the ATA-186 (and formerly the ATA-188, with 1 analogue port compared to 2 ports for the ATA-186, but is End-of-Sale) without the T.38 support.
I am afraid that there aren't other "normal" ATA's from Cisco available. As i mentioned before, your only choice seems to be using an ISR with somekind of analogue expansion module.
CNTSYSNETAG Tue, 11/11/2008 - 00:57
Okay, thank you very much. Do you know the exaxt description or model name of the needed FXS module?
