ibrunello Sat, 02/07/2009 - 10:08
same problem.
sdm routing template is enabled.
I can configure it, but it behaves strangely:
- when I traceroute from a device behind the PBRed VLAN, with an acl which matches the exact source address, the route-map matches just the first packet (the one with TTL=0), but not the following ones (TTL>1).
route-map rmTEST
match ip address aclMATCH
set ip next-hop 10.10.10.1
any hint?
