Cisco 3750 Stacking Issue
arabindas
Hello Everybody,
I have stacked a Cisco WS-3750G-48PS and a Cisco WS-3750-48TS. Will this hardware difference create a issue? Or both should work fine in the stack?
Appreciate your help.
Arabinda
Collin Clark
As long as they have the same IOS versions, it should work fine.
Hope that helps.
Collin Clark
Hope that helps.
Thank you for your response.
Arabinda
just to add to collins comment, if the ios are different minor release then it will work for example one switch is 12.2.44-SE2 and the other is 12.2.44-SE3.
if the swithes have different major release for example one switch is 12.2.44-SE2 and the other is 12.2.46-SE, then it will not work.
Francisco
