Vlan Trunk from Switch to 3845 router with 3 vlans
Answered Question
Nov 7th, 2008
I'm kinda confiused here...
I have a port on a switch configured as :
interface GigabitEthernet10/1
description TRUNK VLAN 227 228 238 switchport
switchport trunk allowed vlan 227,228,238
switchport mode trunk
no ip address
end
The vlan interfaces on the switch are setup and UP-UP.
Now i need to connect this trunk to the router on Fa3/0
Although, I am unsure how to configure the router's Fa3/0 port for all 3 vlans.
I tried setting up sub interfaces on the Fa3/0 as Fa3/0.1 .2 and .3 with encap dot1q and then created the vlans 227 228 and 238 with IP addresses.
The sh int vlan 227 on the router shows:
Vlan227 is up, line protocol is down
Hardware is EtherSVI, address is 0018.b9be.3630 (bia 0018.b9be.3630)
Description: VLAN227
Internet address is 216.24.227.3/24
Why is my vlan not up?
Correct Answer by shevchiksv about 8 years 7 months ago
first of all add vlan to vlan database, if you haven't done this
second you must put on ip address on subintefaces like this:
interface fa3/0
no ip address
interface fa3/0.227
encapsulation dot1q 227
ip address 216.24.227.3 255.255.255.0
interface fa3/0.228
encapsulation dot1q 228
ip address xxx.xxx.xxx.xxx 255.255.255.xxx
and so on
and NEVER WRITE YOUR PUBLIC IP_ADDRESS!!! :))
Overall Rating: 5 (1 ratings)
Correct Answer
shevchiksv Fri, 11/07/2008 - 06:25
interface fa3/0
no ip address
interface fa3/0.227
interface fa3/0.228
and so on
pipsadmin Fri, 11/07/2008 - 06:38
I got confused... with seting up trunks and switch ports on a router...
I had fergot about the vlan ID on the encapsulation dot1q...
OH ! fergot to remove them,////
