ASA5505 backup connection doesnot allow traffic
Nov 7th, 2008
We are trying to get an ASA5505 to function with an fallback internet connection. Everything is connected correctly and sla rule functions the right way but when it is relayed to the backup connection the i can see that the connection is up but the ASA is dropping the packet to the inside. So we can see with the packettracer that is is going outside but the the answer is being dropped by an access-list of the ASA.
A lay-out is attatched as also a config of the ASA.
FredDenHeijer Fri, 11/07/2008 - 07:13
interface Vlan2
backup interface Vlan15
nameif outside
security-level 0
ip address
interface Ethernet0/1
switchport access vlan 15
this is part of the config the backup is connected to the ethernet 0/1.
francisco_1 Fri, 11/07/2008 - 07:55
can upload the deny logs you are seeing on the ASA. try connecting again and send me the deny logs on ASA. use "show logg asdm | inc [ip address of pc you are connecting from"
