LMS 3.0 Deamon Services fails to start
Nov 7th, 2008
Hey,
I recently installed LMS 3.0 and configured it for TACACS ACS but when I restart the daemon service it fails to start up again and all services fail. I reboot the box with the same problem, Daemon services fails to start. I've tried to run the resetloginmodule.pl and even reinstalled the software all with the same results.
Joe Clarke Fri, 11/07/2008 - 07:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What daemons do not start up? If you are having process failures, after about 45 minutes of starting Daemon Manager, the pdshow command should work. The output from that command as well as any errors you're getting would be helpful.
dndncr101 Fri, 11/07/2008 - 07:57
The Ciscoworks Daemon Manager Service will not start on our Windows box.
Joe Clarke Fri, 11/07/2008 - 07:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What is the exact error you're getting when you run "net start crmdmgtd" from a DOS prompt? Also, what errors do you see in the Windows Event Viewer?
dndncr101 Fri, 11/07/2008 - 08:03
I get a mesage stating "The Ciscoworks Daem Manager service could not be started, The service did not report an error. Eventlog says, CRMDmgtd started but it doesn't.
