Callmanager User Page
Answered Question
Nov 7th, 2008
Can someone tell me if in UCM 6.1 if there is still a user page that the users can log into and create speed dials, forwards etc. Thanks
Correct Answer by Rob Huffman about 8 years 3 months ago
Hi Efrain,
Just to add a note to the good tips from Java!
This was answered (beautifully) by Marina earlier this year;
The end user must now be added to the User Group "Standard CCM End Users"
before the ccmuser pages can be accessed.
Please perform following steps in order to add user into User Group:
1) Go to the User Group Page
2) Click the link for Standard CCM End Users
3) Click the Add Users to Group Button
4) Click the check box next to the userid
5) Click the Add selected button
6) Go to the End User Page
7) Click the link for
8) Scoll to the bottom and ensure Standard CCM End Users appears in the
permission section.
9) Login to CCMUser as with configured password.
Use this URL to access.
https://hostname/ccmuser
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 11/07/2008 - 09:01
yes, but you need to add users to the appropriate group for them to access the page, they're not able to log in by default as windows based versions
java
if this helps, please rate
Correct Answer
Rob Huffman Fri, 11/07/2008 - 16:35
Hi Efrain,
permission section.
Hope this helps!
Rob
vjemin Wed, 11/12/2008 - 01:46
Hi Rob,
I have the same problem!!!??? :(((
Well, I have done all these steps with with User Group and Standard CCM End Users, but still I can not log in to user page!?
I don't get any error!?
What else I can try?
Vlaho
a.gooding Tue, 11/18/2008 - 18:00
what ive noticed in some of my "earlier" setups is that if the LDAP integration goes "offline" for want of a better word, you cannot login.
