Jaime Valencia Fri, 11/07/2008 - 09:00
  • Cisco Employee,
  • Hall of Fame,
    2011
if using linux appliance look at the license report, windows versions are honour based licenses and have no reports
java
if this helps, please rate
Jaime Valencia Fri, 11/07/2008 - 09:07
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, license report is an option in CCMadmin linux appliances
java
DMobley1022 Fri, 11/07/2008 - 09:16
So I'm looking at the License Unit Report:
For server x.xxx.xxx.x "Phone License Feature"it says:
Units Authorized: 1300
Units Used: 1312
Units Remaining: -12
How do I find out everything that is using a license?
So right now I'm looking at the License Unit Calculator:
For example I have the following: CISCO TelePresence
Units Consumed Per Device = 6
Current Number of Devices = 0
Number of Units consumed = 0
So does this mean that I have a license for TelePresence, but I'm just not using any?
Same goes for Cisco Unified Personal Communicator:
Units Consumed Per Device = 3
Jaime Valencia Fri, 11/07/2008 - 09:26
  • Cisco Employee,
  • Hall of Fame,
    2011
devices use DLUs.
when you integrate the devices they use from the DLU pool (which is already above what you had bought, you need to either buy more DLUs or register PAKs) we allow that but only temporarily.
Telepresence is a whole other SW, which comes with it's license when you buy it. CUPC also is a separate SW and it also comes with a separate license, same goes for CIPC. there is no reporting of what you have other that the sales orders you have. even those DLUs should be in a sales order. CUCM limits to DLUs and node licenses.
everything you buy comes with a separate license, so if you want that. go thru your sales orders.
java
a.gooding Tue, 11/18/2008 - 18:29
  • Bronze, 100 points or more
Hey
ill try to explain using your example
Units Consumed Per Device = 3 - amount of units that will be used if you have this device
Current Number of Devices = 0 - actual number of devices that you have of this type
Number of Units consumed = 0 - amount of units you are currently using up for these type of devices that reside on your network
therefore in your both examples you are NOT using any DULs.
also, you have -12 UNITS remaining, which means you have exceeded your uploaded licenses.
again to check how much are actually in use
1.for a general output - license report
2. for details on each type of device on your network (ie the Type and amount of phones you are using and the amount of units they consume - License Unit Calculator
