HTTP ASDM access
John Blakley
Is there a way to secure the access for ASDM after a user logs in?
For example:
ssh to public address prompts username and then a password for the enable
http doesn't. You can log into the ASDM with the local username and apply any change you want without using any other authentication. I'm assuming that the ASDM uses elevated authentication? Is there a way around this?
John
HTH, John *** Please rate all useful posts ***
Jagdeep Gambhir
Level 10
Level 10
John,
You need to use command authorization using tacacs or you can also setup local user with different access rights.
With TACACS
http://cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mgaccess.html#wp1042034
~JG
Do rate helpful posts
Jagdeep Gambhir
Level 10
Level 10
John,
With TACACS
~JG
