Unity can't transfer to Translation pattern now
Answered Question
Nov 7th, 2008
Hi I am using ccm 4.1.3 and Unity 4.2.1.
We use to be able to call 5100(call handler) and be able to transfer to a translation pattern(used for speed dial to cell phone) and extensions.
Now only the ext can be dialed. When I dial a translation pattern, the lady says, "I did not reconize that as a valid entry."
Any help is appreicated.
Randall
Correct Answer by Brandon Buffin about 8 years 7 months ago
Randall,
Sounds like at one time the DN for these translation patterns was associated with a Unity subscriber. By default, you can only dial DNs associated with subscribers. If you need to allow callers to dial extensions not associated with a subscriber, take a look at the following post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1ebec/3#selected_message
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Fri, 11/07/2008 - 10:11
  • Purple, 4500 points or more
Randall,
Hope this helps.
Brandon
rcrumm_2 Fri, 11/07/2008 - 11:50
Brandon,
Thank you very much!
You do better searches. :)
Randall
Alejandro Corte... Fri, 07/09/2010 - 15:31
  • Silver, 250 points or more
Hello Brandon,
as Im unable to open the link that you posted is there another way that you can share me the info?
It will be very appreciated,..
