Monitor username for VPN connections through ASA 5510
Nov 7th, 2008
We want to track username, login and logout times for VPN connections through ASA 5510. Is there a way to receive an email notification for those or get that information from a SYSLOG server?
guibarati Tue, 11/11/2008 - 11:27
  • Bronze, 100 points or more
Yes, its already logged in ASDM realtime log.
What you have to do is:
-Open ASDM realtime log
-Connect a vpn
-Look and record the number of the event that appears on "Syslog ID" Column. (There is one for VPN Phase 2 complete(connection) and one for the disconnection)
-If you want it to be sent by email go to:
ASDM---> Logging ---> SMTP
Put here the address of your SMTP server (it should allow relay from ASA)
ASDM---> Logging ---> E-mail Setup
Put the informations (email source and destinations)
ASDM---> Logging ---> Logging filter
Create a filter that send to the email only the events with the Two syslog ID you have seen in the realtime log.
Rate if helpfull
