1131AG getting started
Nov 7th, 2008
Having trouble getting started. I can get the ip set. Then ping successfully. Open my browser and enter the new address - and get connection interrupted.
I'm low tech - just trying to set up an access point with no security.
jeff.kish Fri, 11/07/2008 - 11:22
  • Silver, 250 points or more
How is your AP connected? Is it connected directly to your laptop, or is it on the network? You might need to configure a default-gateway if you're on a different subnet/VLAN as your AP.
Config:
conf t
ip default-gateway x.x.x.x
mtaylor49 Fri, 11/07/2008 - 12:02
My computer and the AP have a 10/100 unmanaged switch in between. My computer provided the ip address (it is the DHCP server). The computer is 172.16.1.243 and the AP is 172.16.1.239.
