IOS APs - Radius Admin Authentication via CLI AND web?
Hi all - I'm wondering if anyone has had luck with setting up administrative authentication to an IOS wireless access point, using some sort of Radius server... and allowing both authentication via the CLI AND web?
I ask because I'm having difficult with the web piece in particular. I'm running TACACS on Radiator (http://www.open.com.au/radiator/technical.html) and having difficulty getting TACACS to respond correctly. According to the TACACS logs, it responds with an "Access-Accept", and in the AP debugs I see a "PASS", but the web interface keeps prompting me for login credentials regardless.
I've been trying to find tips online, but everything I have read makes me think that admin authentication via the web interface may not be possible.
Just for kicks, I'm including some debug info:
AP Debug:
*Mar 1 00:06:13.946: AAA/AUTHEN/LOGIN (00000000): Pick method list 'tacadmin'
*Mar 1 00:06:13.946: TPLUS: Queuing AAA Authentication request 0 for processing
*Mar 1 00:06:13.946: TPLUS: processing authentication start request id 0
*Mar 1 00:06:13.946: TPLUS: Authentication start packet created for 0(UserPIN033)
*Mar 1 00:06:13.946: TPLUS: Using server 169.6.10.205
*Mar 1 00:06:13.948: TPLUS(00000000)/0/NB_WAIT/A41EA4: Started 5 sec timeout
*Mar 1 00:06:13.948: TPLUS(00000000)/0/NB_WAIT: socket event 2
*Mar 1 00:06:13.949: TPLUS(00000000)/0/NB_WAIT: wrote entire 27 bytes request
*Mar 1 00:06:13.949: TPLUS(00000000)/0/READ: socket event 1
*Mar 1 00:06:13.949: TPLUS(00000000)/0/READ: Would block while reading
*Mar 1 00:06:13.952: TPLUS(00000000)/0/READ: socket event 1
*Mar 1 00:06:13.952: TPLUS(00000000)/0/READ: read entire 12 header bytes (expect 16 bytes data)
*Mar 1 00:06:13.952: TPLUS(00000000)/0/READ: read entire 28 bytes response
*Mar 1 00:06:13.952: TPLUS(00000000)/0/A41EA4: Processing the reply packet
*Mar 1 00:06:13.952: TPLUS: Received authen response status GET_PASSWORD (8)
*Mar 1 00:06:13.953: TPLUS: Queuing AAA Authentication request 0 for processing
*Mar 1 00:06:13.954: TPLUS: processing authentication continue request id 0
*Mar 1 00:06:13.954: TPLUS: Authentication continue packet generated for 0
*Mar 1 00:06:13.954: TPLUS(00000000)/0/WRITE/A41EA4: Started 5 sec timeout
*Mar 1 00:06:13.954: TPLUS(00000000)/0/WRITE: wrote entire 28 bytes request
*Mar 1 00:06:13.998: TPLUS(00000000)/0/READ: socket event 1
*Mar 1 00:06:13.998: TPLUS(00000000)/0/READ: read entire 12 header bytes (expect 6 bytes data)
*Mar 1 00:06:13.998: TPLUS(00000000)/0/READ: read entire 18 bytes response
*Mar 1 00:06:13.998: TPLUS(00000000)/0/A41EA4: Processing the reply packet
*Mar 1 00:06:13.998: TPLUS: Received authen response status PASS (2)
*Mar 1 00:06:14.000: AAA/AUTHOR (0x0): Pick method list 'tacadmin'
*Mar 1 00:06:14.000: TPLUS: Queuing AAA Authorization request 0 for processing
*Mar 1 00:06:14.000: TPLUS: processing authorization request id 0
*Mar 1 00:06:14.001: TPLUS: Inappropriate protocol: 23
*Mar 1 00:06:14.001: TPLUS: Sending AV service=shell
*Mar 1 00:06:14.001: TPLUS: Sending AV cmd*
*Mar 1 00:06:14.001: TPLUS: Authorization request created for 0(UserPIN033)
*Mar 1 00:06:14.002: TPLUS: Using server 169.6.10.205
*Mar 1 00:06:14.002: TPLUS(00000000)/0/NB_WAIT/BBB9BC: Started 5 sec timeout
*Mar 1 00:06:14.004: TPLUS(00000000)/0/NB_WAIT: socket event 2
*Mar 1 00:06:14.004: TPLUS(00000000)/0/NB_WAIT: wrote entire 46 bytes request
*Mar 1 00:06:14.004: TPLUS(00000000)/0/READ: socket event 1
*Mar 1 00:06:14.004: TPLUS(00000000)/0/READ: Would block while reading
*Mar 1 00:06:14.008: TPLUS(00000000)/0/READ: socket event 1
*Mar 1 00:06:14.008: TPLUS(00000000)/0/READ: read entire 12 header bytes (expect 39 bytes data)
*Mar 1 00:06:14.008: TPLUS(00000000)/0/READ: read entire 51 bytes response
*Mar 1 00:06:14.008: TPLUS(00000000)/0/BBB9BC: Processing the reply packet
*Mar 1 00:06:14.009: TPLUS (00000000): Got response service = INVALID value Converted to NO_TYPE
*Mar 1 00:06:14.009: TPLUS: Processed AV service=shell cmd* {priv-lvl=15}
*Mar 1 00:06:14.009: TPLUS: received authorization response for 0: PASS
TACACS Log:
Fri Nov 14 01:47:15 2008: DEBUG: TacacsPlus request packet dump:
Fri Nov 14 01:47:15 2008: DEBUG: Decrypting TacacsPlus request
Fri Nov 14 01:47:15 2008: DEBUG: TacacsPlus request decrypted body:
Fri Nov 14 01:47:15 2008: DEBUG: TacacsplusConnection Authorization REQUEST 1, 1, 0, 0, UserPIN033, , , 2, service=shell cmd*
Fri Nov 14 01:47:15 2008: DEBUG: TacacsplusConnection Authorization RESPONSE 1, , , service=shell cmd* {priv-lvl=15}
Fri Nov 14 01:47:15 2008: DEBUG: TacacsplusConnection disconnected from 10.0.0.2:11002
Fri Nov 14 01:47:30 2008: DEBUG: New TacacsplusConnection created for 10.0.0.2:11003
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection request 192, 1, 1, 0, 3660886178, 15
Fri Nov 14 01:47:30 2008: DEBUG: TacacsPlus request packet dump:
Fri Nov 14 01:47:30 2008: DEBUG: Decrypting TacacsPlus request
Fri Nov 14 01:47:30 2008: DEBUG: TacacsPlus request decrypted body:
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection Authentication START 1, 1, 1 for UserPIN033, ,
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection Authentication REPLY 5, 1, Password: ,
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection request 192, 1, 3, 0, 3660886178, 16
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection Authentication CONTINUE 0, ********,
Fri Nov 14 01:47:30 2008: DEBUG: TACACSPLUS derived Radius request packet dump:
Code: Access-Request
Identifier: UNDEF
Authentic: <223><139>s<145>"l<152><147>S<141><165><226>$<137><11>P
Attributes:
NAS-IP-Address = 10.0.0.2
Service-Type = Login-User
User-Name = "UserPIN033"
User-Password = ********
Acc-Service-Profile = "II"
Fri Nov 14 01:47:30 2008: DEBUG: Handling request with Handler 'Acc-Service-Profile=II'
Fri Nov 14 01:47:30 2008: DEBUG: Rewrote user name to UserPIN033
Fri Nov 14 01:47:30 2008: DEBUG: Deleting session for UserPIN033, 10.0.0.2,
Fri Nov 14 01:47:30 2008: INFO: AuthADAM handle_request: Received from 10.0.0.2 port 11003
Fri Nov 14 01:47:30 2008: DEBUG: STEP1: completed; bound to LDAP as utility user
Fri Nov 14 01:47:30 2008: DEBUG: STEP2: completed; have distinguished name of user.
Fri Nov 14 01:47:30 2008: DEBUG: STEP3: completed; bound to LDAP as user.
Fri Nov 14 01:47:30 2008: DEBUG: STEP4: found user in group II-IIRNetwork-OPS
Fri Nov 14 01:47:30 2008: DEBUG: STEP4: completed; searched 1 groups for user membership.
Fri Nov 14 01:47:30 2008: DEBUG: AuthBy ADAM result: ACCEPT,
Fri Nov 14 01:47:30 2008: DEBUG: Access accepted for UserPIN033
Fri Nov 14 01:47:30 2008: DEBUG: Packet dump:
*** Reply to TACACSPLUS request:
Code: Access-Accept
Identifier: UNDEF
Attributes:
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection result Access-Accept
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection Authentication REPLY 1, 0, ,
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection disconnected from 10.0.0.2:11003
Fri Nov 14 01:47:30 2008: DEBUG: New TacacsplusConnection created for 10.0.0.2:11004
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection request 192, 2, 1, 0, 409174207, 34
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection Authorization REQUEST 1, 1, 0, 0, UserPIN033, , , 2, service=shell cmd*
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection Authorization RESPONSE 1, , , service=shell cmd* {priv-lvl=15}
Fri Nov 14 01:47:30 2008: DEBUG: TacacsplusConnection disconnected from 10.0.0.2:11004
Trending Topics - Security & Network
