MDS 9513 clockcard DFM alert
Answered Question
Nov 7th, 2008
Under DFM - Alerts and Activities I'm getting a Utilization alert saying Clockcard is not present. When I go into the device it indeed says it is not present but I'm not given the option to uncheck it so that it won't be monitored. How do I get rid of this alert? See attached.
Correct Answer by Joe Clarke about 8 years 3 months ago
Yeah, it looks like those subclasses are now missing from the FRU list. You shouldn't see any more events for those components moving forward.
Overall Rating: 5 (1 ratings)
Joe Clarke Sun, 11/09/2008 - 11:07
This is currently not doable from within the UI. However, if you have DFM 2.0.10 or higher, you should have some bulk management scripts under NMSROOT/objects/smarts/utils.
Copy the *ManagedStateProcess.asl files to *ManagedStateCard.asl, then modify the scripts so that all instances of "Processor" and "Proc" are replaced with "Card". Then, copy the *StateProc.ksh or .bat files to *StateCard.ksh or .bat, and again change all occurrences of "Processor" and "Proc" to "Card". Then, you will be able to use the instructions found at http://SERVER/help/dfm_newui/bulk_manage.html to unmanage the card you want.
Joe Clarke Sun, 11/09/2008 - 11:27
Actually, given that this is DFM 2.0, it would be better to do:
NMSROOT/objects/smarts/bin/dmctl -s DFM invoke Card::CARD-123.133.5.146/25751 unmanage true
Than, on Solaris:
NMSROOT/objects/smarts/utils/apply.ksh
Or Windows:
NMSROOT\objects\smarts\utils\apply.bat
nancyrawls Mon, 11/10/2008 - 07:49
Found dmctl.exe. What exactly is the command I need to run and what does it do?
Thanks.
Joe Clarke Mon, 11/10/2008 - 09:02
NMSROOT\objects\smarts\bin\dmctl.exe -s DFM invoke Card::CARD-123.133.5.146/25751 unmanage true
Then:
This will unmanage the card in question within DFM.
nancyrawls Mon, 11/10/2008 - 10:04
dmctl> -s DFM invoke Card::CARD-123.133.5.146/25751
Invalid command '-s' -- try again.
Joe Clarke Mon, 11/10/2008 - 10:07
You have run dmctl interactivly. If you ran the command exactly how I wrote it, you should see the dmctl prompt. However, from this prompt, you can do:
Then exit from dmctl, and run the apply.bat command.
nancyrawls Mon, 11/10/2008 - 10:21
dmctl> invoke Card::CARD-123.133.5.146/25751 unmanage true
Not attached.
Joe Clarke Mon, 11/10/2008 - 10:23
It sounds like you just ran dmctl without any arguments. In that case, you would first need to run:
attach DFM
nancyrawls Mon, 11/10/2008 - 10:58
Our tried that with our admin account and it says Permission denied. Is there a default account I can use? It probably wasn't changed. Thanks.
Joe Clarke Mon, 11/10/2008 - 11:03
Exit the dmctl prompt, then run the following command:
NMSROOT\objects\smarts\bin\dmctl -s DFM
What output do you get?
nancyrawls Mon, 11/10/2008 - 11:43
That path is not the path I have therfore it didn't work. I did try running the same command from where my files are located and get the same thing - it's asking for a user id and password:
C:\Program Files\CSCOpx\objects\smarts\bin>dmctl -s DFM
Server DFM User: cisco
cisco's Password: XXXXX
dmctl: Could not attach to 'DFM': Login to Domain Manager failed; permission de
ied
Joe Clarke Mon, 11/10/2008 - 11:45
This is typically admin/admin. However, you can find the value in C:\Program Files\CSCOpx\objects\smarts\conf\clientConnect.conf. This command must succeed for you to accomplish what you want.
nancyrawls Mon, 11/10/2008 - 11:50
Finally! I think that did it. Now I will run the .bat file. I'll let you know how it goes.
Thanks.
Joe Clarke Mon, 11/10/2008 - 12:26
What output do you get for:
dmctl -s DFM getInstances Card_Fault_CiscoEntityFRU
nancyrawls Mon, 11/10/2008 - 12:29
We might be okay. The event just cleared when I ran the same command for the other card. Output:
I-Card_Fault_CiscoEntityFRU-CARD-123.133.187.1/1000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.187.1/2000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.187.1/3000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.190.1/1000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.190.1/2000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.190.1/3000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/25750
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/25751
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/36
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/36
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/25750
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/25751
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/36
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/25750
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/25751
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/36
I-Card_Fault_CiscoEntityFRU-CARD-123.170.0.5/2000
I-Card_Fault_CiscoEntityFRU-CARD-123.170.0.5/3000
I-Card_Fault_CiscoEntityFRU-CARD-123.170.0.5/4000
Correct Answer
Joe Clarke Mon, 11/10/2008 - 12:31
