version 6.x
Nov 7th, 2008
I am getting the error not enough physical disks [0 out of 2 present]
I found this error pertaining to 5.x needing the array controller to be installed in slot 1. Well it is, and I confirm it with the bios report upon boot. I have done many things, and each time it yields the same error.
This is a lab environment, so I am able to do pretty much anything to the system with no worries about taking the system down. Please advise.
Jaime Valencia Fri, 11/07/2008 - 12:58
are you receiving errors when booting up?
maybe something like this??
Waiting for controller to start…..controller not started
Controller #00: IBM ServerRaid 8k-l at PCI Slot :00, Bus:04, Dev:00, Func:00
if so i'd recommend you to open a TAC case, it's probable they need to replace your controller
java
if this helps, please rate
cbestbone Fri, 11/07/2008 - 13:18
no errors at all until the very end. As I wrote before:
Error: not enough physical disks [0 out of 2 present]
The only error.
