Getting %PIX-3-305005: No translation group found
Nov 7th, 2008
I have a PIX 535 running
Cisco PIX Security Appliance Software Version 7.2(3)
Device Manager Version 5.2(3)
the problem I am getting is when I have servers in my DMZ that do not have STATIC Nat statement attached to them get the error code "%PIX-3-305005: No translation group found" when trying to get to the Internet. I have a NAT 0 access list assigning the non static nat servers to the NAT 0 pool (Nat Exempt).
So I am at a loss now. Anyone with an Idea would help thanks
husycisco Fri, 11/07/2008 - 13:48
  • Gold, 750 points or more
Hello William,
Its OK to use exempt NAT and connect to hosts on their real IP addresses internally but you need a NAT statement for connecting to internet, something like following
nat (DMZ) 1 0 0
global (outside) 1 interface
Please post your config if above suggestion does not help
husycisco Fri, 11/07/2008 - 14:03
Ah, hosts have got Public IPs already. Assuming that they are publicly routable try adding the following
access-list dmz_nat0_outbound extended permit ip 205.203.54.0 255.255.255.0 any
logan-7 Fri, 11/07/2008 - 14:07
thanks, will have to wait untill Monday to test. the server manager ( has left the building) will get back with you.
thanks
husycisco Fri, 11/07/2008 - 14:09
Ok then. If you apply the above suggestion, hosts will appear in internet with their own IPs
If you type "nat (dmz) 1 0 0" instead, dmz hosts will connect internet via PATed IP address of outside interface
logan-7 Mon, 11/10/2008 - 11:51
Question:
Will this commain "nat (dmz) 1 0 0" over right Static Nat statement already in place or just dynamically nat devices that do not have any static nat?
husycisco Mon, 11/10/2008 - 13:53
No it wont.
"just dynamically nat devices that do not have any static nat? "
exactly
logan-7 Tue, 11/11/2008 - 07:41
That did work for the Non-static machines.
But I am still having the problem with the machines that has 205.203.54.50.
This one has a static nat to (outside)205.203.58.9. there is a ACL on the outside interface that allows Http and Https to come into the DMZ, and a ACL on the DMZ interface that allows all to go out. But they still cant hit the internet.
any idea
thanks
husycisco Tue, 11/11/2008 - 10:02
Try adding this
access-list dmz_access_in extended permit udp 205.203.54.0 255.255.255.0 any eq dns
