Unity audio file
Answered Question
Nov 7th, 2008
  • Silver, 250 points or more
Somebody know how to add a new audio file in unity connection?
Correct Answer by Jaime Valencia about 8 years 8 months ago
go to whatever you want to upload the greeting, click on the media bar and there is an option to load files from your PC
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 11/07/2008 - 18:37
  • Cisco Employee,
  • Hall of Fame,
    2011
what do you mean??
you want to add a greeting?? a recorded name??
also what verstion are you running?
java
Alejandro Corte... Mon, 11/10/2008 - 05:51
a greeting I have the audio file in mi PC, is the version 5.0
Correct Answer
Jaime Valencia Mon, 11/10/2008 - 07:12
  • Cisco Employee,
  • Hall of Fame,
    2011
java
