Concentrator 3005 LAN-to-LAN
Nov 7th, 2008
Once the IPSec tunnel is established between local and remote sites using Concentrator 3005 on both ends of the WAN link, does anyone know if there is a way to limit access to a specific host in the local site from the remote site in the VPN Concentrator 3005? I couldn't find where this would be implemented; it's either all or nothing.
If this is not possible, will router-to-router tunnel with ACL be able to accomplish the desired task?
Thanks for your input.
Overall Rating: 4 (1 ratings)
Hieu Cao Mon, 11/10/2008 - 10:16
Thanks very much for your response Frarrukh. I'll try it out when we're ready to implement site-site vpn.
