Nm-1CE1T1-PRI on 2821 and 2811
Answered Question
Nov 7th, 2008
How many NM-1ce1t1-pri modules can be installed on cisco 2821 and 2811 ?
Thanks.
Correct Answer by rmcarthur about 8 years 5 months ago
There is only one NM slot on the 2811 and 2821 so you can only fit one NM-1CE1T1-PRI.
Hope this helps.
Overall Rating: 5 (1 ratings)
Correct Answer
rmcarthur Mon, 11/10/2008 - 00:32
  • Bronze, 100 points or more
Hope this helps.
