Modify the Output of Mac- address Table
Nov 8th, 2008
Question.
if we give sh mac-addess-table command we will find somewht this output in switch
VLAN Mac Address Type Ports
IF there is any mac address connected to a port and VLAN and but I want the mac-address should look in the way i want..i.e. somewht 0001.0001.0001 instead of original one
Can it can be done...
This is possible and there are some commands for this which i am confused will run on all IOS or not...
aghaznavi Thu, 11/13/2008 - 14:56
  • Silver, 250 points or more
Use this command this helps you to view Mac address details
show mac-address-table vlan - Displays information about the MAC address table for a specific VLAN.
show mac-address-table address - Displays the information about the MAC-address table.
show mac-address-table count - Displays the number of entries currently in the MAC address table.
For further information click this link.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/44sg/command/reference/show1.html#wp2055991
