Problem in 7985 Ip phone
Nov 8th, 2008
Hi All,
i am facing problem with cisco Video Phone 7985 .I had configured it for Directory number X earlier and was working fine.
suddenly,somebody did some changes & changed number to Y.I deleted the directory number Y but it is still showing on display as Y.
Now when we make a call for X or Y , call is landing on same phone.But when 7985 user makes a call , number displayed on receiving end is Y.
I deleted directory number and phone,while re-adding phone ,it automatically picks up the same number Y ,even though it is not existing in any of configs in CCM.
I tried changing the ip phone & added directory number X which is working fine
Can somebody guide on the same.?
regds,
aman
Jaime Valencia Sat, 11/08/2008 - 08:18
  • Cisco Employee,
  • Hall of Fame,
    2011
did you deleted the DN from the unassigned DNs before recreating the device??
java
if this helps, please rate
amansoi_5 Tue, 11/11/2008 - 17:21
I did not do this.I will check & let u know.
regds,
aman
amansoi_5 Wed, 11/12/2008 - 17:16
I did not find the desired number in UNASSIGNED Number.
regds,
aman
