Static Natting
Nov 8th, 2008
Hi, We have two ISP links following:
1) 1.1.1.0/24-----Outside
2) 2.2.2.0/24-----Outside2
Internal Network : 192.168.10.0/24-Inside
Using commands for natting and patting i.e
nat (Inside) 1 192.168.10.0 255.255.255.0
global (outside) 1 interface
Now I want to use static natting and allot one static public IP from the range of Ist ISP Provider Pool 1.1.1.2---Map with----192.168.10.2
And second public IP wud use from the 2nd ISP Provider pool 2.2.2.2----map with---192.168.10.3
All Internal Traffic are going out from outside Interface that means first static IP will work but how its possible that the second static natting 2.2.2.2 traffic to be bypass from second outside link (Outside2). Please help.
JORGE RODRIGUEZ Sat, 11/08/2008 - 09:31
Ray, are you configuring asa for backup isp?
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
with above link you can try for inbound traffic through backup isp via (outside2) .
global (outside2) 1 interface
route outside 0.0.0.0 0.0.0.0 1
route outside2 0.0.0.0 0.0.0.0 <254>
sla monitor 123
type echo protocol ipIcmpEcho interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
Then static NAT and inbound acl to allow traffic to both hosts
static (inside,outside) 1.1.1.2 192.168.10.2 netmask 255.255.255.255
static (inside,outside2) 2.2.2.2 192.168.10.3 netmask 255.255.255.255
access-list outside_access_in extended permit tcp any host 1.1.1.2 eq log
access-group outside_access_in in interface outside
access-list outside2_access_in extended permit tcp any host 2.2.2.2 eq log
access-group outside2_access_in in interface outside2
Jorge
ray_stone Sat, 11/08/2008 - 20:17
Hi Jorge,
Thanks for your reply. Here I don't want to use ISP outside2 as a backup link, just want to know if i dont use nat and global commands and instead of that i use only static commands like follwoing:
Will both Internal Servers be accessible from outside network from its own Public Address difined and can i access the internet from Servers as I believe that Nat and PAT are used only other machines which are not using static IP's and what would be the route commands in this case?
And what is a use of these commands:
sla monitor 123
num-packets 3
frequency 10
