Etherchannel configuration
itdsmartnet
hi, i have the following configuration regarding etherchannel. i want to know that is that interface is in access mode or in trunk mode. what does the command "switchport access vlan 109" has effect on this etherchannel. is it going to forward only vlan 109 traffic to the etherchannel or all vlan traffic will go through this etherchannel
interface TenGigabitEthernet4/3
switchport
switchport mode trunk
channel-protocol lacp
channel-group 2 mode active
interface TenGigabitEthernet4/4
switchport
It will only take effect if you configure the switchport as access port:
interface TenGig4/3
switchport mode access
Then it will be part of vlan 109.
If you use this interface as a trunk, then the "switchport access vlan 109" is unnecessary.
Cheers:
Istvan
Jon Marshall
Should act as a trunk - what is under the port-channel interface - po2.
Easiest way to see what is happening regarding trunking is "sh interface trunk".
Jon
Istvan_Rabai
Level 7
Level 7
Hi Waseem,
Agree with Jon.
The "switchport mode trunk" command will determine the mode of operation of the link.
No matter if you configured "switchport access vlan 109".
Cheers:
Istvan
hi,
Thanks for your reply, what is the effect of switchport access vlan 109. if i remove this command does it matter on configuration.
interface TenGig4/3
Cheers:
Istvan
