aaa max failed attempts/RADIUS
Nov 8th, 2008
Is there an aaa command or server command that limits the maximum number of failed attempts one can try before getting cut off. I note there is one for local. but I fail to find one that applies to aaa that is auth against radius. am I missing somthing or does this not exist.
Or will I have to use aaa accounting, and work this out on my radius server/database schema. anyway, I would
rather not have to work through the details that way, I would prefer there be a way to do this via IOS....this is IOS 12.3 not pix/asa
Thanks for the help!
cg
Premdeep Banga Sat, 11/08/2008 - 08:05
  • Gold, 750 points or more
have you tried, this command,
aaa authentication attempts login number-of-attempts
By default, if user fails authentication (no authorization), then user is allowed 3 attempts. This can be changed using above command.
In above case I am talking about administrative authentication to the device.
Prem
