Cisco 1711 IOS Version
Nov 8th, 2008
Hi all,
Does anwyone know which IOS I need to install on my Cisco 1711 router so that when I type in show ver it says Cisco 1711 insteatd of Cisco IPM (MPC86). I need to ge the proper IOS because SDM is not working because of this Cisco IPM version issue
niall-wilkins Tue, 11/11/2008 - 03:15
Cisco1711#show ver
Cisco IOS Software, C1700 Software (C1700-ADVSECURITYK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 14:11 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r)XM4, RELEASE SOFTWARE (fc1)
Cisco1711 uptime is 1 day, 20 hours, 30 minutes
System returned to ROM by reload
System image file is "flash:c1700-advsecurityk9-mz.124-15.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco IPM (MPC862P) processor (revision 0x101) with 115885K/15187K bytes of memory.
Processor board ID FOC08078M0Q (1743016855), with hardware revision 0000
MPC862P processor: part number 7, mask 0
1 Ethernet interface
5 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Edison Ortiz Tue, 11/11/2008 - 06:12
Niall,
After some research, it seems the problem is seen when the router has a faulty hardware component. Can you provide the show diag output?
Thanks.
__
Edison.
Edison Ortiz Tue, 11/11/2008 - 06:15
BTW, if you aren't using a feature that only is available in the T train, I recommend staying away from it.
You should try the mainline train, IOS release c1700-advsecurityk9-mz.124-21a.bin
HTH,
__
Edison.
niall-wilkins Wed, 11/12/2008 - 17:41
Cisco1711#show diag
Slot 0:
Unknown Port adapter, 5 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
PCB Serial Number : FOC08078M0Q
Part Number : 73-8969-01
Board Revision : B0
Fab Version : 04
Product (FRU) Number : Unknown
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 48 41 01 01 C1 8B 46 4F 43 30 38 30
0x10: 37 38 4D 30 51 82 49 23 09 01 42 42 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC/VIC Slot 0:
4 Port FE Switch
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 1.0
Part Number : 73-8958-01
Board Revision : C0
Deviation Number : 0-0
Fab Version : 01
PCB Serial Number : FOC082520KQ
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 800-24817-01
Connector Type : 01
Base MAC Address : 0012.0087.a7ac
MAC Address block size : 20
Product (FRU) Number : WIC-4ESW
CLEI Code : IPMED00BRA
Edison Ortiz Wed, 11/12/2008 - 18:34
Slot 0:
This can be the root of the problem. What's on that slot?
Can you try installing the mainline IOS version I recommended?
__
Edison.
niall-wilkins Thu, 11/13/2008 - 05:38
I have installed the recommended version here is the output:
Cisco_1711#show ver
Cisco IOS Software, C1700 Software (C1700-ADVSECURITYK9-M), Version 12.4(21a), RELEASE SOFTWARE (fc1)
Compiled Mon 29-Sep-08 13:38 by prod_rel_team
Cisco_1711 uptime is 9 hours, 54 minutes
System image file is "flash:c1700-advsecurityk9-mz.124-21a.bin"
[email protected].
Cisco IPM (MPC862P) processor (revision 0x101) with 114688K/16384K bytes of memory.
32K bytes of NVRAM.
Cisco_1711#show diag
Slot 0:
Board Revision : B0
Fab Version : 04
WIC/VIC Slot 0:
4 Port FE Switch
Board Revision : C0
Fab Version : 01
RMA History : 00
Connector Type : 01
Edison Ortiz Thu, 11/13/2008 - 06:43
My research indicates this is causing the problem:
Slot 0:
Since the device is a fixed model, not modular, you would need to replace the unit. It's an EOL product and I assume it's not under Cisco warranty. If the name issue is that important to you, I recommend upgrading the hardware to a 1800 model.
HTH,
__
Edison.
Please rate helpful posts
