MAC address of linksys router wrt54g
Answered Question
Nov 8th, 2008
Hi all,
i have linksys router at home model is
WRT54G.It is 4 port Router.I have wi fi
connection with cable router and router connects to shaw cable modem.
MY PC Gateway IP is 192.168.1.1
and mac address of Gateway is 00:1D:7E:53:2B:09.my question is in Linksys router which NIC or port this MAC is assigned to??.I check the website
Search results for "00-1d-7e"
MAC Address
Prefix Vendor
001D7E Cisco-Linksys, LLC
Also when i log onto linksys router it has different Mac address there which is
00:1D:7E:53:2B:08
and IP is 96.51.153.154.
SO also i want to know this second MAC is assigned to which port in Linksys router?
Many thanks
mahesh
Correct Answer by MUHAMMAD SHAHEEN about 8 years 8 months ago
Hi Mahesh,
Yes,
Hope this helps...
Shaheen
Overall Rating: 5 (2 ratings)
ohassairi Sun, 11/09/2008 - 01:21
  • Silver, 250 points or more
00:1D:7E:53:2B:09 should be the address of the 4 ports internal switch..
the second one is for the external port connected to internet
mahesh18 Sun, 11/09/2008 - 11:36
so 4 ports on the router have 4 different
mac addresses.
or
the all ports of router have 1 Mac address?
Let me get clear on this.
many thanks
mahesh
MUHAMMAD SHAHEEN Sun, 11/09/2008 - 12:20
Hi Mahesh,
These routers do have 4 port switchable ports but each port does not have its own mac address. Each port registers the and then uses the mac address of client device.
You can go-to the configuration page using browser and go to status tab -->Local Network-->DHCP Client Table. this table will dispaly the mac add of each client connected to each port. once the client is removed, the mac is removed and switchport is no longer active.
as far the the 2 mac addresses you see on your status router page. 1 address is for the external link connecting to ISP and the second one is for the internal LAN side 192.168.1.1
you can identify these by using the command prompt on your PC connected to this router, by issuing arp -a command
the mac which is attached to 192.168.1.1 is your default gateway is internal LAN and the other will be external WAN.
Hope This Helps.....
Shaheen
mahesh18 Sun, 11/09/2008 - 14:16
Hi shahem
thanks for your reply
i got the answer.
mahesh18 Sun, 11/09/2008 - 14:19
So my understanding is that these Routers
have 2 NIc cards one for ISP side and one for Local Lan side.And these two NIC have there own MAC address.Is that right?
Correct Answer
MUHAMMAD SHAHEEN Mon, 11/10/2008 - 03:48
Hi Mahesh,
Yes,
Hope this helps...
Shaheen
