No IOS Image on Cisco 1100 Series AP
Nov 8th, 2008
Hi fella,
I have a problem with this Cisco 1100 AP, LED Light said: Red-Green-Red
here a link @ http://www.cisco.com/en/US/docs/wireless/access_point/1100/installation/guide/110h_c6.html
I tried to obtaining IP Address from AP, no response IP Address from Windows Vista, tried 10.0.0.1 in from website address. Cannot Response.
How do I solution? I'm newbie.
andrewlow Sun, 11/09/2008 - 12:41
Try reverting the AP to IOS, using the c1100-k9w7-tar.default file name method as mentioned in the link.
playstation3 Sun, 11/09/2008 - 19:29
How do I put???? I don't know how to put this in AP??? Help me...
andrewlow Mon, 11/10/2008 - 01:48
Read the section ;
"Using the MODE Button to Return the Access Point to Autonomous Mode " in the link in your original post.
To summarise;
Step one: Change your workstation address to 10.0.0.29/24
Step two: Rename IOS image (tar file) to c1100-k9w7-tar.default
Step three: setup tftp server
Step four: Connect AP and workstation to switch or interconnect with a crossover cable.
Step five: Turn on AP while holding down mode button for +- 20 seconds (Radio led turns red) then release mode button
Step 6: Wait until the access point reboots, as indicated by all led's turning green followed by the Status led blinking green
playstation3 Wed, 11/12/2008 - 19:12
Won't work for me using AP to PC. Can you fix my AP for me?
jeff.kish Thu, 11/13/2008 - 14:32
  • Silver, 250 points or more
Try a crossover cable if you cannot connect to the AP with your PC. It's an 1100, right? 1100s do not support auto-MDIX.
playstation3 Fri, 11/14/2008 - 20:54
Do you mean CAT5 cable? Yes. I tried it but it didn't work. I tried Ping 10.0.0.1 then no response from AP. I need my ap back to Cisco System for fix it.
playstation3 Thu, 11/13/2008 - 17:57
I think it is IOS Software Someone put wrong IOS Image in it
playstation3 Sun, 11/30/2008 - 19:51
I'd RECOMMENDED IOS Software NEED to add for putting wrong IOS Software then it will tell you for IOS failure, reboot for get old IOS Software back without getting problem.
playstation3 Sun, 11/30/2008 - 19:54
And I tried everything. I dont have any tool (Cisco controller, many thing). I like Cisco System because it best network technology.
BUT it LOT money than all.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
