NTP synchronization
Nov 9th, 2008
Hello, thank you for your time.
We have a 4507 and we face a problem with NTP synchronization.
Here my command:
ntp server 192.168.103.200 key 0 prefer
However the "ntp status" return the following error:
"Clock is unsynchronized, stratum 16, no reference clock"
And the "sh ntp associations" shows the NTP server as configured but not synced.
Do you have any ideas?
Overall Rating: 5 (1 ratings)
glen.grant Sun, 11/09/2008 - 05:25
Did you try it without the key 0 reference. Usually will mean there is no path to the specific address . Also there are issues if this is a microsoft server you are trying to sync with .
counanefr Sun, 11/09/2008 - 05:47
Thank very much for your quick answer.
I tried without the "key 0" argument and it works perfectly.
Thank you again
