Dial-Peers to support 10 and 7 digit Local Dialing
Nov 9th, 2008
I just implemented SRST and have one remaining sticking point.
Using these peers:
dial-peer voice 12 pots
description Local Dialing
destination-pattern 9[2-9]......
port 0/0/0:23
forward-digits 7
dial-peer voice 13 pots
trunkgroup SRST-PSTN
description Local 10 Digit Dialing
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:23
forward-digits 10
The router will IMMEDIATELY match dial peer 12 and I am unable to use 10 digit dialing.
How can I concurrently support both 10 and 7 digit local dialing?
Kris Thompson Sun, 11/09/2008 - 11:23
Sometimes it only takes asking the question to get the answer. I added a T on the end of the 7 digit destination pattern to force the pattern to be longer than the 10 digit local dial. It now works (with an interdigit delay which is acceptable).
destination-pattern 9[2-9]......T
Marwan ALshawi Sun, 11/30/2008 - 02:45
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
by the way have u noticed that it will will take a while till dial out with the T !!!
this is because interdigit timeout
u can dial # after the number
or u can decrease the inter digit time out under the fallback mode
hope this helpful
